Salta al contenuto principale
Minolta Maxxum STsi Clock Battery Replacement
Cosa ti serve
  1. Minolta Maxxum STsi Clock Battery Replacement, Clock Battery: passo 1, immagine 1 di 1
    • Press up firmly on the back-cover release on the right side of the camera to release the back panel.
  2. Minolta Maxxum STsi Clock Battery Replacement: passo 2, immagine 1 di 1
    • Use a coin to twist open the battery compartment (twist counterclockwise).
  3. Minolta Maxxum STsi Clock Battery Replacement: passo 3, immagine 1 di 1
    • Use tweezers to lift off the battery compartment cover.
  4. Minolta Maxxum STsi Clock Battery Replacement: passo 4, immagine 1 di 1
    • Use tweezers to take out the old clock battery and replace it with a new one.
Conclusione
2 Commenti
Will the camera itself stop working if there is no clock battery?
Olivia Ortiz - Replica
nope. it’s don’t stop working without clock battery
Pavel Gogin -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 873
