Salta al contenuto principale
Minolta Maxxum QTSI Tripod Mount Replacement
Cosa ti serve
  1. Minolta Maxxum QTSI Tripod Mount Replacement, Tripod Mount: passo 1, immagine 1 di 1
    • With a screwdriver, remove the (7) black Phillips #00 5.0mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
  2. Minolta Maxxum QTSI Tripod Mount Replacement: passo 2, immagine 1 di 2 Minolta Maxxum QTSI Tripod Mount Replacement: passo 2, immagine 2 di 2
    • Once all the screws are removed, the panel should easily come off.
    • Remove the bottom panel of the camera by placing your index finger and thumb on the outer edges of the panel.
    • Pull the bottom panel towards you, it should come off easily.
  3. Minolta Maxxum QTSI Tripod Mount Replacement: passo 3, immagine 1 di 1
    • The tripod socket is visible when the bottom panel is removed.
    • Remove the (3) black Phillips #00 6.25mm screws from the tripod socket.
    • When the screws are removed, the tripod socket is free and can easily be lost.
  4. Minolta Maxxum QTSI Tripod Mount Replacement: passo 4, immagine 1 di 2 Minolta Maxxum QTSI Tripod Mount Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers to gently remove the tripod socket, and replace it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 384
