Salta al contenuto principale
Minolta Dimage Xt SD Card Replacement
  1. Minolta Dimage Xt SD Card Replacement, SD Card: passo 1, immagine 1 di 2 Minolta Dimage Xt SD Card Replacement, SD Card: passo 1, immagine 2 di 2
    • Locate the latch labeled BATT SD CARD on the right side of the camera.
    • Push the latch in the direction of the arrow, and it will spring open.
  2. Minolta Dimage Xt SD Card Replacement: passo 2, immagine 1 di 2 Minolta Dimage Xt SD Card Replacement: passo 2, immagine 2 di 2
    • Insert the SD card into the smaller of the two slots. The metallic connectors should enter the camera first and the label of the SD card can be seen from a front view of the camera.
    • Push the card all the way into the slot until there is a click, and the card stays in place.
    • To remove the SD card, push the card down and release. The card will pop up and can be pulled the rest of the way out.
Conclusione
When the card has been removed/inserted, push the latch down, and it will lock into place.
Megan Milam
Membro da: 03/11/13
28 Reputazione
5 Guide realizzate
Clemson, Team 12-4, Benson Spring 2013 Membro di Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,248
