Salta al contenuto principale
Minolta Dimage Xt Casing Replacement
Cosa ti serve
  1. Minolta Dimage Xt Casing Replacement, Casing: passo 1, immagine 1 di 3 Minolta Dimage Xt Casing Replacement, Casing: passo 1, immagine 2 di 3 Minolta Dimage Xt Casing Replacement, Casing: passo 1, immagine 3 di 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Casing Replacement: passo 2, immagine 1 di 3 Minolta Dimage Xt Casing Replacement: passo 2, immagine 2 di 3 Minolta Dimage Xt Casing Replacement: passo 2, immagine 3 di 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
Conclusione
To reassemble your device, follow these instructions in reverse order. The outer casing must be properly in place and screws tight to protect the internal hardware.
Megan Milam
Membro da: 03/11/13
56 Reputazione
5 Guide realizzate
Clemson, Team 12-4, Benson Spring 2013 Membro di Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Membri
14 Guide realizzate
1Commento della guida
How to reattach the ribbon????
rosybrier - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 512
