Salta al contenuto principale
Minolta Dimage Xt Capture Button Replacement
Cosa ti serve
  1. Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, immagine 1 di 3 Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, immagine 2 di 3 Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, immagine 3 di 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Capture Button Replacement: passo 2, immagine 1 di 3 Minolta Dimage Xt Capture Button Replacement: passo 2, immagine 2 di 3 Minolta Dimage Xt Capture Button Replacement: passo 2, immagine 3 di 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Capture Button Replacement, Capture Button: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Choosing the front half of the casing, locate the capture button on the top.
    • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
  4. Minolta Dimage Xt Capture Button Replacement: passo 4, immagine 1 di 1
    • The button will spring free. The capture device consists of the plastic button and a small metal spring.
    • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
Conclusione
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
Membro da: 03/11/13
56 Reputazione
5 Guide realizzate
Clemson, Team 12-4, Benson Spring 2013 Membro di Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 636
