Salta al contenuto principale
Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement
Cosa ti serve
  1. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement, Gearcase Insulator: passo 1, immagine 1 di 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement, Gearcase Insulator: passo 1, immagine 2 di 2
    • Pull up on the shoe release lever until it's perpendicular to the gearcase insulator.
  2. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement: passo 2, immagine 1 di 1
    • Pull the shoe assembly out from the saw.
  3. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement: passo 3, immagine 1 di 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement: passo 3, immagine 2 di 2
    • Remove the gearcase insulator by folding over the rubber, dislodging the insulator from the red shift lever, and pulling it off.
    • Using the screwdriver to help lift the rubber over the lever and folding it over may be helpful.
  4. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement, Shoe Retainer: passo 4, immagine 1 di 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement, Shoe Retainer: passo 4, immagine 2 di 2
    • Use a Torx T20 screwdriver to remove the two 4.2 mm screws that secure the shoe retainer.
    • The second screw is on the opposite side.
  5. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement: passo 5, immagine 1 di 1
    • The shoe pin attaches the retainer to the gearcase and will need to be removed to fully remove the retainer.
    • Use a flathead screwdriver to push the shoe pin from one side of the gearcase to the other.
    • Twist the pin with your finger to remove the pin from the saw.
  6. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement: passo 6, immagine 1 di 1
    • Remove the shoe retainer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 35
