Salta al contenuto principale
Milwaukee M12 2407-20 Speed Selector Lever Replacement
Cosa ti serve
  1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Speed Selector Lever Replacement: passo 2, immagine 1 di 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: passo 3, immagine 1 di 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: passo 3, immagine 2 di 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: passo 3, immagine 3 di 3
    • Remove the unit from the housing assembly and set the housing assembly aside.
  4. Milwaukee M12 2407-20 Speed Selector Lever Replacement: passo 4, immagine 1 di 1
    • Use a spudger to pry the broken speed selector lever off the assembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,607
