Salta al contenuto principale
Milwaukee M12 2407-20 Shuttle Spring Plate Replacement
Cosa ti serve
  1. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: passo 2, immagine 1 di 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: passo 3, immagine 1 di 3 Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: passo 3, immagine 2 di 3 Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: passo 3, immagine 3 di 3
    • Use both hands to lift and remove the gear case assembly from the shell casing.
    • Set the gear case assembly aside.
  4. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: passo 4, immagine 1 di 2 Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: passo 4, immagine 2 di 2
    • Remove the forward/reversing shuttle to gain access to the spring plate.
  5. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: passo 5, immagine 1 di 1
    • Remove the spring plate and insert replacement spring plate.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,279
