Salta al contenuto principale
Milwaukee M12 2407-20 Outer Casing Replacement
Cosa ti serve
  1. Milwaukee M12 2407-20 Outer Casing Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Outer Casing Replacement: passo 2, immagine 1 di 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 32
Tutti i Tempi: 3,278
