Salta al contenuto principale
Milwaukee Impact Wrench 9070-20 Power Cord Replacement
Cosa ti serve
  1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: passo 1, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: passo 1, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: passo 1, immagine 3 di 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using the T20 Torx screwdriver.
    • Remove the four 14mm screws using the same screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 2, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 2, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 2, immagine 3 di 3
    • Hold the device so the gray part faces directly towards you.
    • Remove the four screws on the sides using the T20 Torx screwdriver.
    • After removing all screws, use a small plastic pry bar to slide the gearbox assembly forward slightly.
  3. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 3, immagine 1 di 2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 3, immagine 2 di 2
    • Gently remove the upper clam shell from the device.
    • Lift a black colored power cord from its mount at the bottom of the device, so it can move freely.
  4. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 4, immagine 1 di 2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 4, immagine 2 di 2
    • Disconnect the brown field winding wire from the white ac power cord wire.
  5. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 5, immagine 1 di 2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 5, immagine 2 di 2
    • Disconnect the black ac power wire from the connector on the bottom of the forward / reverse switch.
    • Remove the AC power cord and replace it with a new one.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 14
Tutti i Tempi: 342
