Salta al contenuto principale
Milwaukee Impact Wrench 9070-20 Motor Field Winding Replacement
Cosa ti serve
  1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: passo 1, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: passo 1, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: passo 1, immagine 3 di 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 2, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 2, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 2, immagine 3 di 3
    • Remove the four screws on each corner of the gear box assembly using a T-20 Screwdriver.
    • Use a plastic opening tool, slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 3, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 3, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 3, immagine 3 di 3
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The motor brushes may need to be compressed to help with the removal of the gearbox assembly.
  4. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 4, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 4, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 4, immagine 3 di 3
    • Disconnect the black AC wire from the brown field wire.
    • Disconnect the black field wire from the switch.
  5. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: passo 5, immagine 1 di 1
    • Pull straight up on the field winding to remove it from the body.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 16
Tutti i Tempi: 375
