Salta al contenuto principale
Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch
Cosa ti serve
  1. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: passo 1, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: passo 1, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: passo 1, immagine 3 di 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 2, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 2, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 2, immagine 3 di 3
    • Remove the four screws on each corner of the gear box assembly using a T20 Torx screwdriver.
    • Use a plastic pry bar slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 3, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 3, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 3, immagine 3 di 3
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The bushes may need to be compressed for easier removal of the motor.
  4. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 4, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 4, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 4, immagine 3 di 3
    • Pull up on the switch to remove it from the plastic mount.
    • There are six wires connected to the back of the switch.
    • Remove the black field wire winding from the switch.
  5. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 5, immagine 1 di 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 5, immagine 2 di 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 5, immagine 3 di 3
    • Remove the blue lower brush wire (top right) from the connector.
    • Remove the black AC power wire from the switch.
    • The wires do not need to be removed in order, but doing so helps to minimize confusion.
  6. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 6, immagine 1 di 2 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: passo 6, immagine 2 di 2
    • Flip the switch vertically.
    • Remove the white upper brush wire from the connector.
    • Reconnect all wires and replace the new switch back into the plastic case mount.
    • Ensure that all wires are clear of the case so that they will not be damaged on reassembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 18
Tutti i Tempi: 854
