Salta al contenuto principale
Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement
Cosa ti serve
  1. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: passo 1, immagine 1 di 1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: passo 2, immagine 1 di 2 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: passo 2, immagine 2 di 2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: passo 3, immagine 1 di 2 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: passo 3, immagine 2 di 2
    • Locate the black forward/reverse button underneath the chuck.
    • Pull the button gently towards you to remove it from the trigger assembly.
  4. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: passo 4, immagine 1 di 1
    • Using replacement part NO. 45-24-D013 (forward/reverse shuttle), follow the steps of this guide in reverse order.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 730
