Salta al contenuto principale
Milwaukee Hex Impact Driver 2750-20 Output Shaft Bearing Replacement
Cosa ti serve
  1. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 2, immagine 1 di 1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Output Shaft Bearing: passo 3, immagine 1 di 1
    • Once the interior is open locate the output shaft driver pictured at the left of the screen.
  4. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 4, immagine 1 di 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 4, immagine 2 di 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 4, immagine 3 di 3
    • Lift the driver head and motor assembly directly out of the outer casing.
    • Pull the driver head away from the motor assembly, separating the two.
  5. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 5, immagine 1 di 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 5, immagine 2 di 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the fan and the drive shaft assembly from the motor core assembly.
    • Using a pair of tweezers, remove the retaining ring.
    • Remove the old bearing and reinstall the new retaining clip.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 586
