Salta al contenuto principale
Milwaukee Hex Impact Driver 2750-20 Driver Head Replacement
Cosa ti serve
  1. Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement: passo 2, immagine 1 di 1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Driver Head: passo 3, immagine 1 di 3 Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Driver Head: passo 3, immagine 2 di 3 Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Driver Head: passo 3, immagine 3 di 3
    • Lift the driver head and motor assembly directly out of the outer casing.
    • Pull the driver head away from the motor assembly, separating the two.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 571
