Salta al contenuto principale
Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement
Cosa ti serve
  1. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Battery: passo 1, immagine 1 di 2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Battery: passo 1, immagine 2 di 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: passo 2, immagine 1 di 2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: passo 2, immagine 2 di 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Electric Motor: passo 3, immagine 1 di 2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Electric Motor: passo 3, immagine 2 di 2
    • Remove the two 6mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
  4. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: passo 4, immagine 1 di 2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: passo 4, immagine 2 di 2
    • Remove the gear case and electric motor assembly from the impact driver case by pulling up on it.
  5. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: passo 5, immagine 1 di 1
    • The gear case is easily separated from the electric motor by gently pulling the two pieces apart.
  6. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: passo 6, immagine 1 di 2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: passo 6, immagine 2 di 2
    • Insert the opening pick between one of the carbon brushes and the electric motor to help compress the spring.
    • While compressing the spring slide that section of the brush block assembly over the bearing.
    • The brush block assembly should easily slide over the bearing now , if it does not repeat the above process as needed for the other three carbon brushes.
    • When you remove the brush block assembly, the remaining component is the electric motor.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 43
Tutti i Tempi: 1,471
