Salta al contenuto principale
Milwaukee Hex Impact Driver 2656-20 Case Disassembly
Cosa ti serve
  1. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Battery: passo 1, immagine 1 di 2 Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Battery: passo 1, immagine 2 di 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: passo 2, immagine 1 di 2 Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: passo 2, immagine 2 di 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 49
Tutti i Tempi: 2,140
