Salta al contenuto principale
Milwaukee Hackzall 2625-20 Gearbox Replacement
Cosa ti serve
  1. Milwaukee Hackzall 2625-20 Gearbox Replacement, Outer Casing: passo 1, immagine 1 di 2 Milwaukee Hackzall 2625-20 Gearbox Replacement, Outer Casing: passo 1, immagine 2 di 2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Gearbox Replacement, Gearbox: passo 2, immagine 1 di 1
    • Open up the device.
    • Remove the screws that are connecting the shoe to the gearbox using the T15 Torx screwdriver to remove 14.0 mm screws.
    • Pull out the shoe and gearbox to remove the screw on the other side
  3. Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 3, immagine 1 di 3 Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 3, immagine 2 di 3 Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 3, immagine 3 di 3
    • Using your finger, push the rubber band up then slide the shoe off of the blade clamping mechanism.
  4. Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 4, immagine 1 di 3 Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 4, immagine 2 di 3 Milwaukee Hackzall 2625-20 Gearbox Replacement: passo 4, immagine 3 di 3
    • Detach the gearbox from the motor.
    • Remove the screws from the gearbox to expose the blade camping mechanism, then pull out the blade clamping mechanism from the gearbox. You will use a T15 Torx screwdriver to remove 14.0 mm screws.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,938
