Salta al contenuto principale
Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement
Cosa ti serve
  1. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement, Outer Casing: passo 1, immagine 1 di 2 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement, Outer Casing: passo 1, immagine 2 di 2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement, Blade Clamping Mechanism: passo 2, immagine 1 di 1
    • Open up the device.
    • Remove the screws that are connecting the shoe to the gearbox using the T15 Torx screwdriver to remove 14.0 mm screws. You will need to pull out the shoe and gearbox to get to the screw on the other side.
  3. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: passo 3, immagine 1 di 3 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: passo 3, immagine 2 di 3 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: passo 3, immagine 3 di 3
    • Using your finger, push the rubber band up to allow you to slide the shoe off of the blade clamping mechanism.
  4. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: passo 4, immagine 1 di 3 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: passo 4, immagine 2 di 3 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: passo 4, immagine 3 di 3
    • Detach the gearbox from the motor.
    • Remove the screws from the gearbox to expose the blade camping mechanism, then pull out the blade clamping mechanism from the gearbox. Use a T15 Torx screwdriver to remove five 14.0 mm screws.
  5. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: passo 5, immagine 1 di 2 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: passo 5, immagine 2 di 2
    • Remove the external retaining ring.
    • Next, remove the frontcam.
    • Then, take out the pin.
    • Remove the cam collar.
    • Remove the sleeve.
    • Remove the torsion spring.
    • Lastly, remove the spring cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,637
