Salta al contenuto principale
Milwaukee 5262-21 Reduction Gear Assembly Replacement
Cosa ti serve
  1. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Housing Assembly: passo 1, immagine 1 di 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: passo 3, immagine 1 di 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: passo 3, immagine 2 di 2
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 4, immagine 1 di 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 4, immagine 2 di 2
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 5, immagine 1 di 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 5, immagine 2 di 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 5, immagine 3 di 3
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 6, immagine 1 di 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 6, immagine 2 di 2
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 7, immagine 1 di 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 7, immagine 2 di 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 7, immagine 3 di 3
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 8, immagine 1 di 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 8, immagine 2 di 2
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 9, immagine 1 di 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 9, immagine 2 di 2
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 10, immagine 1 di 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 10, immagine 2 di 2
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 11, immagine 1 di 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 11, immagine 2 di 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 11, immagine 3 di 3
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 12, immagine 1 di 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 12, immagine 2 di 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: passo 12, immagine 3 di 3
    • Now pull the reduction gear assembly up and out of the diaphragm.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,320
