Salta al contenuto principale
Milwaukee 5262-21 Power Cord Replacement
Cosa ti serve
  1. Milwaukee 5262-21 Power Cord Replacement, Housing Assembly: passo 1, immagine 1 di 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Power Cord Replacement: passo 2, immagine 1 di 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Power Cord Replacement, Power Cord: passo 3, immagine 1 di 2 Milwaukee 5262-21 Power Cord Replacement, Power Cord: passo 3, immagine 2 di 2
    • Remove the two 11.5mm T-15 screws shown in red.
  4. Milwaukee 5262-21 Power Cord Replacement: passo 4, immagine 1 di 3 Milwaukee 5262-21 Power Cord Replacement: passo 4, immagine 2 di 3 Milwaukee 5262-21 Power Cord Replacement: passo 4, immagine 3 di 3
    • Follow the black and white cord to the trigger.
    • On the trigger there are two small bolts that you have to loosen.
    • Loosen them slightly with a H - 1.5 bit.
  5. Milwaukee 5262-21 Power Cord Replacement: passo 5, immagine 1 di 3 Milwaukee 5262-21 Power Cord Replacement: passo 5, immagine 2 di 3 Milwaukee 5262-21 Power Cord Replacement: passo 5, immagine 3 di 3
    • Once the bolts are loose you can pull both cords straight out from the trigger.
    • Pull the cable from the chassis and put it to the side and it has been successfully removed.
Conclusione
Adrien Andrade-Cain
Membro da: 03/08/19
181 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 293
