Introduzione
If you need to replace the motor housing in the rotary hammer, use this guide to take apart the device. You will be following a step by step guide, that will help you in replacing the motor house, you may also refer to the pictures attached to each step for guidance.
Cosa ti serve
Now the two 10mm T-10 screws shown in red can be removed.
Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
