Salta al contenuto principale
Milwaukee 5262-21 Motor Housing Replacement
Cosa ti serve
  1. Milwaukee 5262-21 Motor Housing Replacement, Housing Assembly: passo 1, immagine 1 di 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Motor Housing Replacement: passo 2, immagine 1 di 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: passo 3, immagine 1 di 2 Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: passo 3, immagine 2 di 2
    • Now the two 10mm T-10 screws shown in red can be removed.
    • Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
  4. Milwaukee 5262-21 Motor Housing Replacement: passo 4, immagine 1 di 2 Milwaukee 5262-21 Motor Housing Replacement: passo 4, immagine 2 di 2
    • Using the metal spudger, remove each brush holder as shown in the images.
  5. Milwaukee 5262-21 Motor Housing Replacement: passo 5, immagine 1 di 3 Milwaukee 5262-21 Motor Housing Replacement: passo 5, immagine 2 di 3 Milwaukee 5262-21 Motor Housing Replacement: passo 5, immagine 3 di 3
    • Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
  6. Milwaukee 5262-21 Motor Housing Replacement: passo 6, immagine 1 di 2 Milwaukee 5262-21 Motor Housing Replacement: passo 6, immagine 2 di 2
    • After removing the four screws, pull apart the the two sections.
  7. Milwaukee 5262-21 Motor Housing Replacement: passo 7, immagine 1 di 2 Milwaukee 5262-21 Motor Housing Replacement: passo 7, immagine 2 di 2
    • Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
    • These screws hold the fan baffle in place.
  8. Milwaukee 5262-21 Motor Housing Replacement: passo 8, immagine 1 di 2 Milwaukee 5262-21 Motor Housing Replacement: passo 8, immagine 2 di 2
    • Remove the fan baffle by pulling it out.
  9. Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: passo 9, immagine 1 di 2 Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: passo 9, immagine 2 di 2
    • Pull the black wire(shown in the image) out of the trigger assembly.
  10. Milwaukee 5262-21 Motor Housing Replacement: passo 10, immagine 1 di 2 Milwaukee 5262-21 Motor Housing Replacement: passo 10, immagine 2 di 2
    • Pull the white wire (shown in the image) out of the trigger assembly.
  11. Milwaukee 5262-21 Motor Housing Replacement: passo 11, immagine 1 di 2 Milwaukee 5262-21 Motor Housing Replacement: passo 11, immagine 2 di 2
    • Using a metal spudger slide the black wire (shown in the image) out of the trigger assembly.
  12. Milwaukee 5262-21 Motor Housing Replacement: passo 12, immagine 1 di 2 Milwaukee 5262-21 Motor Housing Replacement: passo 12, immagine 2 di 2
    • Using a metal spudger slide the yellow wire (shown in the image) out of the trigger assembly.
  13. Milwaukee 5262-21 Motor Housing Replacement: passo 13, immagine 1 di 3 Milwaukee 5262-21 Motor Housing Replacement: passo 13, immagine 2 di 3 Milwaukee 5262-21 Motor Housing Replacement: passo 13, immagine 3 di 3
    • After disconnecting the wires, push the 120v Field Assembly out of the motor housing.
    • You may need to use a screwdriver to push the assembly from behind.
  14. Milwaukee 5262-21 Motor Housing Replacement: passo 14, immagine 1 di 3 Milwaukee 5262-21 Motor Housing Replacement: passo 14, immagine 2 di 3 Milwaukee 5262-21 Motor Housing Replacement: passo 14, immagine 3 di 3
    • Once the assembly is loose, pull each half out of the housing.
    • Note the orientation of how the halves sit together in the housing before removal.
  15. Milwaukee 5262-21 Motor Housing Replacement: passo 15, immagine 1 di 2 Milwaukee 5262-21 Motor Housing Replacement: passo 15, immagine 2 di 2
    • Remove the motor housing from the device.
Conclusione
Andrew Floyd
Membro da: 03/08/19
277 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 9
Tutti i Tempi: 284
