Salta al contenuto principale
Milwaukee 2780-20 Trigger Assembly Replacement
Cosa ti serve
  1. Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: passo 1, immagine 1 di 3 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: passo 1, immagine 2 di 3 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: passo 1, immagine 3 di 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 Trigger Assembly Replacement: passo 2, immagine 1 di 3 Milwaukee 2780-20 Trigger Assembly Replacement: passo 2, immagine 2 di 3 Milwaukee 2780-20 Trigger Assembly Replacement: passo 2, immagine 3 di 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 Trigger Assembly Replacement: passo 3, immagine 1 di 1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 Trigger Assembly Replacement: passo 4, immagine 1 di 3 Milwaukee 2780-20 Trigger Assembly Replacement: passo 4, immagine 2 di 3 Milwaukee 2780-20 Trigger Assembly Replacement: passo 4, immagine 3 di 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,151
