Introduzione
If your wondering why your tool is not cutting properly, you may have a worn blade. This is a simple procedure on how to remove the blade, which is an important component to the angle grinder. A variety of wheels and attachments are available for the grinder to preform certain task.
In order to remove the flange nut you must turn it counter-clockwise.
Once the nut is removed, take off the old blade and install a new one.
