Salta al contenuto principale
Milwaukee 2780-20 (2) Ball Bearings Replacement
Cosa ti serve
  1. Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: passo 1, immagine 1 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: passo 1, immagine 2 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: passo 1, immagine 3 di 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 2, immagine 1 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 2, immagine 2 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 2, immagine 3 di 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 3, immagine 1 di 1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 4, immagine 1 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 4, immagine 2 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 4, immagine 3 di 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
  5. Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: passo 5, immagine 1 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: passo 5, immagine 2 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: passo 5, immagine 3 di 3
    • Using a Torx T20 screwdriver to remove four 6mm screws located on top of the gearcase assembly.
  6. Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 6, immagine 1 di 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 6, immagine 2 di 2
    • Pull the gearcase away from electronic assembly to expose the inside.
  7. Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 7, immagine 1 di 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 7, immagine 2 di 2
    • Using a 3/8 Wrench, Remove the nut located in the center of the Gearcase.
    • The nut and pinion should immediatley come apart from the rotor assembly.
  8. Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 8, immagine 1 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 8, immagine 2 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 8, immagine 3 di 3
    • Pull the rotor assembly apart from the gearcase casing.
  9. Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 9, immagine 1 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 9, immagine 2 di 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 9, immagine 3 di 3
    • Using a Torx T15 screwdriver, remove the two 4mm screws to take the bearing retainer off.
  10. Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 10, immagine 1 di 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: passo 10, immagine 2 di 2
    • Use a hammer to knock out the bearing and begin installing the new one before reassembling.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 47
Tutti i Tempi: 2,987
