Salta al contenuto principale
Milwaukee 2704-20 Trigger Replacement
Cosa ti serve
  1. Milwaukee 2704-20 Trigger Replacement, Outer Case: passo 1, immagine 1 di 2 Milwaukee 2704-20 Trigger Replacement, Outer Case: passo 1, immagine 2 di 2
    • Remove the battery from the drill.
  2. Milwaukee 2704-20 Trigger Replacement: passo 2, immagine 1 di 3 Milwaukee 2704-20 Trigger Replacement: passo 2, immagine 2 di 3 Milwaukee 2704-20 Trigger Replacement: passo 2, immagine 3 di 3
    • Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
  3. Milwaukee 2704-20 Trigger Replacement: passo 3, immagine 1 di 3 Milwaukee 2704-20 Trigger Replacement: passo 3, immagine 2 di 3 Milwaukee 2704-20 Trigger Replacement: passo 3, immagine 3 di 3
    • Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
    • If the cover doesn't come off easily, check for any clips or latches that may be holding it in place. These can usually be released by pressing them with a small flathead screwdriver.
  4. Milwaukee 2704-20 Trigger Replacement, Trigger: passo 4, immagine 1 di 2 Milwaukee 2704-20 Trigger Replacement, Trigger: passo 4, immagine 2 di 2
    • Desolder the two solder joints on the trigger assembly.
    • USE CAUTION! Soldering irons get extremely hot, as will everything they make prolonged contact with.
  5. Milwaukee 2704-20 Trigger Replacement: passo 5, immagine 1 di 2 Milwaukee 2704-20 Trigger Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, remove the header connector.
    • To avoid damage, be careful replicating this step in both the removal and replacement processes.
  6. Milwaukee 2704-20 Trigger Replacement: passo 6, immagine 1 di 1
    • Remove the trigger mechanism entirely.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 23
Tutti i Tempi: 346
