Salta al contenuto principale
Milwaukee 2704-20 Control Switch Replacement
Cosa ti serve
  1. Milwaukee 2704-20 Control Switch Replacement, Outer Case: passo 1, immagine 1 di 2 Milwaukee 2704-20 Control Switch Replacement, Outer Case: passo 1, immagine 2 di 2
    • Remove the battery from the drill.
  2. Milwaukee 2704-20 Control Switch Replacement: passo 2, immagine 1 di 3 Milwaukee 2704-20 Control Switch Replacement: passo 2, immagine 2 di 3 Milwaukee 2704-20 Control Switch Replacement: passo 2, immagine 3 di 3
    • Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
  3. Milwaukee 2704-20 Control Switch Replacement: passo 3, immagine 1 di 3 Milwaukee 2704-20 Control Switch Replacement: passo 3, immagine 2 di 3 Milwaukee 2704-20 Control Switch Replacement: passo 3, immagine 3 di 3
    • Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
    • If the cover doesn't come off easily, check for any clips or latches that may be holding it in place. These can usually be released by pressing them with a small flathead screwdriver.
  4. Milwaukee 2704-20 Control Switch Replacement, Control Switch: passo 4, immagine 1 di 3 Milwaukee 2704-20 Control Switch Replacement, Control Switch: passo 4, immagine 2 di 3 Milwaukee 2704-20 Control Switch Replacement, Control Switch: passo 4, immagine 3 di 3
    • Remove the control switch.
    • It is not attached to anything and should slide out easily. Take note of orientation and be sure to replace it in the same position.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 33
Tutti i Tempi: 304
