Salta al contenuto principale
Mill Cutter Paper Stripper Replacement
Cosa ti serve
  1. Mill Cutter Paper Stripper Replacement, Mill cutter paper stripper set and stripper guide set: passo 1, immagine 1 di 1
    • Unplug the shredder from the wall electrical outlet.
    • Remove the shredder from its catch basket and place it face down on a flat surface.
  2. Mill Cutter Paper Stripper Replacement: passo 2, immagine 1 di 3 Mill Cutter Paper Stripper Replacement: passo 2, immagine 2 di 3 Mill Cutter Paper Stripper Replacement: passo 2, immagine 3 di 3
    • Locate the seven case screws and remove them with a Phillips screwdriver. The screws are identified by the seven marked circles. The screws are 15 mm in length and the head diameter is 5 mm.
    • Remove the manufacturer’s label in order to get to one of the hidden screws, if applicable.
  3. Mill Cutter Paper Stripper Replacement: passo 3, immagine 1 di 2 Mill Cutter Paper Stripper Replacement: passo 3, immagine 2 di 2
    • Remove the screws connecting the stripper guide and the base of the shredder's housing unit with a Phillips screwdriver. The diameter head and screws are 10 mm in length.
  4. Mill Cutter Paper Stripper Replacement: passo 4, immagine 1 di 2 Mill Cutter Paper Stripper Replacement: passo 4, immagine 2 di 2
    • Once all of the screws have been removed, pull the casing apart.
    • Remove the stripper guide from the housing unit.
    • Use caution to prevent the trigger guard from falling apart.
  5. Mill Cutter Paper Stripper Replacement: passo 5, immagine 1 di 3 Mill Cutter Paper Stripper Replacement: passo 5, immagine 2 di 3 Mill Cutter Paper Stripper Replacement: passo 5, immagine 3 di 3
    • Remove the e-clips from the gears on the left side with a flathead screwdriver.
    • Remove screws from the gear box cover on the right side with a Phillips screwdriver. The screws are identified by the two marked circles. The screws are 7 mm in length and the head diameter is 3 mm.
  6. Mill Cutter Paper Stripper Replacement: passo 6, immagine 1 di 3 Mill Cutter Paper Stripper Replacement: passo 6, immagine 2 di 3 Mill Cutter Paper Stripper Replacement: passo 6, immagine 3 di 3
    • Remove the gears from both sides.
    • If the gears are hard to remove, use a flathead screwdriver to help remove them. The gears also may be greasy so place them on a paper towel or newspaper.
    • Remove the screws from the gearbox side plate with Phillips screwdriver to get to the gears. The screws are 7 mm in length and the head diameter is 3 mm.
  7. Mill Cutter Paper Stripper Replacement: passo 7, immagine 1 di 2 Mill Cutter Paper Stripper Replacement: passo 7, immagine 2 di 2
    • Replace the mill cutter paper stripper set and stripper guide set.
    • Use protective gloves as the blades are very sharp.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,194
