Salta al contenuto principale
Mid F900 Camera Replacement
Cosa ti serve
  1. Mid F900 Camera Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Camera Replacement: passo 2, immagine 1 di 2 Mid F900 Camera Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Camera Replacement, Camera: passo 3, immagine 1 di 1
    • Near the top left of the device, gently unclip the gold ribbon cable by pulling up the black clip holding it in place and removing the ribbon.
  4. Mid F900 Camera Replacement: passo 4, immagine 1 di 1
    • Remove the old camera by carefully lifting it straight up.
    • Place the new camera in its place.
Conclusione
USF Tampa, Team 6-6, Remmell Fall 2016 Membro di USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 151
