Salta al contenuto principale
Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
Cosa ti serve
  1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: passo 1, immagine 1 di 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: passo 1, immagine 2 di 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: passo 1, immagine 3 di 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: passo 2, immagine 1 di 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: passo 2, immagine 2 di 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: passo 2, immagine 3 di 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: passo 3, immagine 1 di 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: passo 3, immagine 2 di 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
    • Use tweezers to push these tabs in.
    • Gently pull the plastic covering off of the upper lid.
  4. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: passo 4, immagine 1 di 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: passo 4, immagine 2 di 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: passo 4, immagine 3 di 3
    • Grab the plastic wire housing near the serial port.
    • Gently pull and jiggle the wire housing until it comes free from the circuit board.
  5. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: passo 5, immagine 1 di 2 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: passo 5, immagine 2 di 2
    • Gently lift up the bulbs and remove the wires from the plastic.
    • After completely freeing the bulbs, buy new ones and replace.
Conclusione
Cal Poly, Team 6-9, Regan Fall 2011 Membro di Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,163
