Introduzione
Faulty battery or logic board? Replace them!
Cosa ti serve
Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
Use a Zune opening tool to pry the digitizer ribbon cable connector up off the logic board.
Use a Zune opening tool to push the small plastic clip securing the logic board near its lower left edge toward the headphone jack while gently lifting the upper edge of the logic board.
Use a Zune opening tool to pull the plastic clip away from the logic board while gently pulling the board away from the bottom edge of the Zune.
Altre 9 persone hanno completato questa guida.
2 Commenti
thanks, dude, that was really helpful
Last step is missing to show how to disconnect the battery from the board.. is it soldered ?
