Salta al contenuto principale
Microsoft Zune 80 Case Replacement
Cosa ti serve
  1. Microsoft Zune 80 Case Replacement, Case: passo 1, immagine 1 di 1
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. Microsoft Zune 80 Case Replacement: passo 2, immagine 1 di 1
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
  3. Microsoft Zune 80 Case Replacement, Remove the Casing: passo 3, immagine 1 di 2 Microsoft Zune 80 Case Replacement, Remove the Casing: passo 3, immagine 2 di 2
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
Conclusione
turey
Membro da: 11/11/09
408 Reputazione
2 Guide realizzate
Cal Poly, Team 6-5, Maness Fall 2009 Membro di Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
5 Membri
5 Guide realizzate
1Commento della guida
I have followed these steps but im unable to get the back case off, any tips for a stubborn backing?
zippy9765 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 91
Tutti i Tempi: 4,960
