Salta al contenuto principale
Microsoft Zune 80 Battery Replacement
Cosa ti serve
  1. Microsoft Zune 80 Battery Replacement, Case: passo 1, immagine 1 di 1
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. Microsoft Zune 80 Battery Replacement: passo 2, immagine 1 di 1
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
    These ended up being T3 screws for me.
    Terry Hashley, Jr - Replica
  3. Microsoft Zune 80 Battery Replacement, Remove the Casing: passo 3, immagine 1 di 2 Microsoft Zune 80 Battery Replacement, Remove the Casing: passo 3, immagine 2 di 2
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
  4. Microsoft Zune 80 Battery Replacement, Remove the Silver Tape: passo 4, immagine 1 di 2 Microsoft Zune 80 Battery Replacement, Remove the Silver Tape: passo 4, immagine 2 di 2
    • Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
  5. Microsoft Zune 80 Battery Replacement: passo 5, immagine 1 di 3 Microsoft Zune 80 Battery Replacement: passo 5, immagine 2 di 3 Microsoft Zune 80 Battery Replacement: passo 5, immagine 3 di 3
    • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive.
    • If the cable doesn't come off easily, the black bar has not been un-clicked.
    • The hard drive cable (ZIF cable) is very fragile. Try to keep it in its original shape and bend it as little as possible.
    • Now gently pull the orange hard drive cable to remove it from the hard drive.
    • Lift the hard drive from the device.
    • Hard Drive Replacement Only: Check to make sure the hard drive cable is in good condition and then connect the new hard drive in the same place, following the steps in reverse order.
  6. Microsoft Zune 80 Battery Replacement, Battery: passo 6, immagine 1 di 2 Microsoft Zune 80 Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Remove two more pieces of silver tape from the bottom of the device. One of these pieces is below the other.
  7. Microsoft Zune 80 Battery Replacement: passo 7, immagine 1 di 1
    • Remove the two T4 screws holding the headphone jack receiver on the top left corner of the device.
  8. Microsoft Zune 80 Battery Replacement: passo 8, immagine 1 di 2 Microsoft Zune 80 Battery Replacement: passo 8, immagine 2 di 2
    • Remove the two T4 screws holding the metal brackets on both sides of the bottom of the device.
    • Remove the screws, brackets, and clips from the device. These are small pieces, so put them in a safe place.
  9. Microsoft Zune 80 Battery Replacement: passo 9, immagine 1 di 1
    • The orange audio board cable is clipped in with a small black bar, same as the hard drive cable. Un-clip the bar by pushing upwards on the edge of the black bar towards the orange cable. You will hear it click when is disengages.
    • WARNING: If the cable doesn't come off easily, the black bar has not been un-clicked.
  10. Microsoft Zune 80 Battery Replacement: passo 10, immagine 1 di 1
    • Flip the black bar to unclip the left side of the hard drive cable. You can now remove the hard drive cable.
  11. Microsoft Zune 80 Battery Replacement: passo 11, immagine 1 di 2 Microsoft Zune 80 Battery Replacement: passo 11, immagine 2 di 2
    • Remove the two T4 screws that hold the charging port on the bottom of the device.
    • Remove the charging port.
  12. Microsoft Zune 80 Battery Replacement: passo 12, immagine 1 di 3 Microsoft Zune 80 Battery Replacement: passo 12, immagine 2 di 3 Microsoft Zune 80 Battery Replacement: passo 12, immagine 3 di 3
    • Remove the battery from the device with the cables still connected.
    • Carefully lift up the mother board located at the base of the Zune. Unclip the orange ribbon cable in the same manner as in the previous steps.
    • Remove the mother board from the Zune, leaving the black wire connected.
    I thought these had tri lobe screws holding the cover....mine does
    Robert Miller - Replica
Conclusione
Altre 21 persone hanno completato questa guida.
koolkid
Membro da: 10/28/09
499 Reputazione
2 Guide realizzate
Cal Poly, Team 6-5, Maness Fall 2009 Membro di Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
5 Membri
5 Guide realizzate
9 Commenti
Where can you get a zune battery? Model 1376 120GB
Evan Freach - Replica
battery replacement can be found at https://www.ebay.com/itm/364192772728.
PROHIBIDO EL PASO -
Where can you get a battery?
Ethan Leroux - Replica
changing email and passwords are bad at the same time
nutcase too - Replica
On the 120 GB model, the cap in Step 1 is one complete unit. You should follow step 2 first.
scheppdogg532 - Replica
So if the black bar in the last step snaps in half, and you discover that ribbon cable is already half-severed, you’re screwed?
mushfacebox - Replica
guide also works for Zune 120, 4, 8 and 16
PROHIBIDO EL PASO - Replica
Anybody know a repair shop that can fix the battery on my zoom, replace it. The battery is dead.
Jake Jake - Replica
Anybody know of a repair place that can fix my zoomAnybody know of a repair place that can fix? My Zune kneed new battery
Jake Jake - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 259
Tutti i Tempi: 44,219
