Introduzione
This guide will help in the removal and replacement of the battery for the Microsoft Zune 80.
Cosa ti serve
Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
There are two T3 screws under the cap. Remove both with a T3 screwdriver.
Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive.
Now gently pull the orange hard drive cable to remove it from the hard drive.
Lift the hard drive from the device.
Hard Drive Replacement Only: Check to make sure the hard drive cable is in good condition and then connect the new hard drive in the same place, following the steps in reverse order.
Remove two more pieces of silver tape from the bottom of the device. One of these pieces is below the other.
Remove the battery from the device with the cables still connected.
Carefully lift up the mother board located at the base of the Zune. Unclip the orange ribbon cable in the same manner as in the previous steps.
Remove the mother board from the Zune, leaving the black wire connected.
Altre 21 persone hanno completato questa guida.
9 Commenti
Where can you get a zune battery? Model 1376 120GB
battery replacement can be found at https://www.ebay.com/itm/364192772728.
Where can you get a battery?
changing email and passwords are bad at the same time
On the 120 GB model, the cap in Step 1 is one complete unit. You should follow step 2 first.
So if the black bar in the last step snaps in half, and you discover that ribbon cable is already half-severed, you’re screwed?
guide also works for Zune 120, 4, 8 and 16
