Salta al contenuto principale
Microsoft Surface Pro Battery Replacement
Cosa ti serve
  1. Microsoft Surface Pro Battery Replacement, Display: passo 1, immagine 1 di 1
    • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
    • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
  2. Microsoft Surface Pro Battery Replacement: passo 2, immagine 1 di 2 Microsoft Surface Pro Battery Replacement: passo 2, immagine 2 di 2
    • Apply a suction cup as close as possible to the edge of the display.
    • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
    • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
    • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
    • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
  3. Microsoft Surface Pro Battery Replacement: passo 3, immagine 1 di 2 Microsoft Surface Pro Battery Replacement: passo 3, immagine 2 di 2
    • Starting from the top edge, lift the display slightly. If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
    • Before completely removing the display, disconnect the three display cables.
  4. Microsoft Surface Pro Battery Replacement: passo 4, immagine 1 di 1
    • Remove the display.
  5. Microsoft Surface Pro Battery Replacement, Battery: passo 5, immagine 1 di 2 Microsoft Surface Pro Battery Replacement, Battery: passo 5, immagine 2 di 2
    • Using a T3 Torx screwdriver, remove a total of 23 screws from the screen bezel of the Surface Pro.
  6. Microsoft Surface Pro Battery Replacement: passo 6, immagine 1 di 1
    • Lift the screen bezel from the Surface Pro.
  7. Microsoft Surface Pro Battery Replacement: passo 7, immagine 1 di 2 Microsoft Surface Pro Battery Replacement: passo 7, immagine 2 di 2
    • Remove the 6 T5 screws from the panels on each side of the frame.
    • Remove 23 T2 screws from the panels.
  8. Microsoft Surface Pro Battery Replacement: passo 8, immagine 1 di 1
    • Lift both metal panels from the frame.
  9. Microsoft Surface Pro Battery Replacement: passo 9, immagine 1 di 2 Microsoft Surface Pro Battery Replacement: passo 9, immagine 2 di 2
    • Using tweezers, gently pull the eight orange ribbon cables from their sockets.
  10. Microsoft Surface Pro Battery Replacement: passo 10, immagine 1 di 2 Microsoft Surface Pro Battery Replacement: passo 10, immagine 2 di 2
    • Unscrew the 17 T5 torx screws on the mother board with the T5 torx screw driver
  11. Microsoft Surface Pro Battery Replacement: passo 11, immagine 1 di 1
    • Once all screws are removed, gently lift up the logic board with your hands to pull it out.
  12. Microsoft Surface Pro Battery Replacement: passo 12, immagine 1 di 2 Microsoft Surface Pro Battery Replacement: passo 12, immagine 2 di 2
    • Use your hands to pry off the entire battery pack with enough force to overcome the glue keeping the batteries in place.
Conclusione
Altre 35 persone hanno completato questa guida.
Jonathan Choi
Membro da: 10/09/13
1.005 Reputazione
4 Guide realizzate
Cal Poly, Team 8-20, Regan Fall 2013 Membro di Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 Membri
16 Guide realizzate
24 Commenti
Thank you for that awesome guide!
Do you know where can i buy a battery for surface pro 2??
Thanks
John john - Replica
I am also trying to find out where to acquire the Surface Pro batteries...???
Tristan Irons -
im also looking for a surface pro replacement battery.
Lekan Adesanya - Replica
I just bought one for $70 at a site called newpower99.com... should be here in 2 days. I have no idea if it will work, but it says it comes with a toolkit to replace it. I hope it works.
Matt -
Did you have success installing the Newegg battery?
asmac - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 44
Ultimi 7 Giorni: 322
Ultimi 30 Giorni: 1,457
Tutti i Tempi: 229,461
