Introduzione
Use this guide to remove or replace the motherboard in a Microsoft Surface Pro 6.
Applying new thermal paste to the CPU during reassembly may improve the performance of your Surface. If you wish to do that, make sure you have new thermal paste and either high-concentration isopropyl alcohol or a specialized thermal paste cleaner.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
Cosa ti serve
Passo 1 Heat the screen
Attenzione: i passaggi 1-22 provengono da una guida contrassegnata come in corso.
If the screen's glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass. Lay overlapping strips of clear packing tape over the display until all the glass is covered. Wear safety glasses to protect your eyes.
Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
Take note of the screen adhesive layout before continuing:
These areas only contain adhesive and are safe to cut.
The display board and flex cables sit here close to the edge. Cut very carefully and do not insert the pick as deep under the display.
Fragile antenna cables lie under this part of the screen. Carefully follow the procedure to avoid damaging them. The adhesive is also the thickest here.
Be careful at the bottom of the screen also. If you put the picks in too far, you can severe the screen ribbon cables which happened to me. I successfully removed the screen without breaking it but severed those cables.
Insert an opening pick into the speaker opening on the screen and slide the pick under the glass. Do not press the pick into the speaker grille, as the grille is easily torn.
Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
Leave this opening pick in the right edge to prevent the adhesive from resealing.
Insert a new opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
Leave this pick in the bottom edge to prevent the adhesive from resealing.
Avoid pressing the pick more than 5mm into the lower edge. Driving the pick in as far as the edge of the bezel on the lower edge will damage ribbon cables.
Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
Use an opening pick to cut through any remaining adhesive.
Lift the top of the screen assembly away from the case while sliding the bottom of the screen closer to the motherboard display connectors.
Gently lay the screen down on the case with the connectors facing up. Take care to avoid creasing the display cables.
No llega el cable derecho de la pantalla, al voltear la Tablet y este se romperá, lo ideal sera levantar la pantalla un poco y desconectar el cable de la tablet no de la pantalla.
Use an opening pick to pry up one edge of the EMI shield covering the display board.
Repeat this procedure at different points around the shield until it is free.
I had better results using the black spudger to free the shields without damaging them.
Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
Repeat this procedure at different points around the shield until it is free. Remove the shield.
Remove the screen assembly from the Surface.
During reassembly, pause here and follow this guide to replace the screen adhesive.
Use the point of a spudger to pry the microphone connector straight up and out of its socket on the motherboard.
Use a T5 Torx driver to remove the four screws securing the antenna support:
Three 4.5 mm screws
One 6 mm screw
Use a spudger to lift the antenna support out of its recess in the Surface.
Remove the antenna support.
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
Black spudger worked best to get the emu shields out without damaging them.
Remove the ten Torx screws securing the heat sink:
Five 2.6 mm-long T3 screws
Four 3.3 mm-long T5 screws
Screw 1
Screw 2
Screw 3
Screw 4
Just like to add, on my i7, there is a fan in the top left corner and the heat sink is glued to the cover. The cover must be removed using a ph0 x 3 and one T3 (I think that is the sizes)
As the other person commented, mine also had a fan connected to the heatsink. This is present in the version with an Intel Core i7-7660U. It requires removing a T3 and T5 screw and the fan connector. Below is a link to an image showing this step.
While I do not have the fan present in my i5 version, the copper heat pipe does extend further down on the far left side (as oriented in the picture). There is an additional T3 screw on this arm as well as a small dab of adhesive on the very end.
Use the point of a spudger to lift the left speaker connector out of its socket on the motherboard.
Use the point of a spudger to flip up the small locking flap securing the volume and power button cable ZIF connector.
Slide the volume and power button cable straight out of its socket on the motherboard.
Use the point of a spudger to lift the right speaker connector out of its socket on the motherboard.
Use a T5 Torx driver to remove the two screws securing the right speaker:
One 6 mm screw
One 3.7 mm screw
Use a spudger to lift the left edge of the right speaker so that it clears the components around the speaker.
With the left edge lifted, slide the speaker to the left, straight out of its recess in the case.
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the camera connectors.
Use the flat end of a spudger to pry the front-facing camera connector up and out of its socket on the motherboard.
Use the flat end of a spudger to pry the rear-facing camera connector up and out of its socket on the motherboard.
Use the flat end of a spudger to pry the microphone connector up and out of its socket on the motherboard.
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the microSD card reader connector.
Use the flat end of a spudger to pry the microSD card reader connector up and out of its socket on the motherboard.
Use the flat end of a spudger to lift the flap that sits over the SurfaceConnect port connector.
Use the point of a spudger to flip up the small locking flap securing the headphone jack cable ZIF connector.
Slide the headphone jack cable straight out of its socket on the motherboard.
Insert one point of a pair of pointed tweezers into a gap in the corner of the left-most of the remaining large EMI shields.
Use a T3 Torx driver to remove the eight 2.5 mm screws securing the motherboard.
Lift the non-port-side of the motherboard up slightly, just enough so that it clears the components around it and the edge of the case.
Slide the motherboard away from the ports. Make sure the ports are completely out of their slots in the case before removing the motherboard.
Remove the motherboard.
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the display interconnect connector.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
Altre 10 persone hanno completato questa guida.
Un commento
Wonderful tutorial! So very glad I found it! Thank you for the through, step by step with Excellent, sequential photos of disassembly.
Thanks for taking the time to show this proceedure, it's a great service to those of us who wish to repair our own equipment ... even though Microsoft doesn't want us to be able to do so.
Excellent Tutorial!!
You may want to discharge the battery completely as I found it quite easy to accidentally bump the power button and turn the surface on while cutting through the screen adhesive.
Emma Strainis - Replica
