Introduzione
Follow this guide to replace or upgrade the SSD in your Microsoft Surface Laptop 7 (13.8‑inch).
Before starting this repair, read through Microsoft's guide on best practices for SSD removal.
Cosa ti serve
Unplug all cables and fully shut down your laptop.
Close your laptop and lay it down so the rubber feet are facing up.
Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
Use your tweezers to pry up and remove the foot.
Repeat the process to remove the remaining feet.
Attrezzo utilizzato in questo passaggio:FixMat$31.41
Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
Heat an iOpener and lay it on the SSD for one minute to heat the tape on its left edge.
Use a Torx Plus 5IP screwdriver to remove the 2.9 mm‑long screw securing the SSD.
Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
Altre 5 persone hanno completato questa guida.
5Commenti sulla guida
Any other SSD will work. I replaced mine with a 1tb drive after I cloned the original. Reinstalled and it was like nothing happened. No need to update windows or anything. I used DiskGenius but use whatever safe program you prefer.
Is there a need to remove the battery?
Hello! You don't need to remove the battery, just disconnect it to avoid damaging your laptop.
also. this needs to say it needs DISM to backup drivers first
