Salta al contenuto principale
Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement
Cosa ti serve
  1. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Prepare your laptop for disassembly: passo 1, immagine 1 di 2 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Prepare your laptop for disassembly: passo 1, immagine 2 di 2
    • Allow your laptop's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    Chiedi a FixBot
  2. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Flip the laptop over: passo 2, immagine 1 di 2 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Flip the laptop over: passo 2, immagine 2 di 2
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
    Chiedi a FixBot
  3. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Feet removal information: passo 3, immagine 1 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Feet removal information: passo 3, immagine 2 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Feet removal information: passo 3, immagine 3 di 3
    • Each foot has a recess to help pry it from the laptop:
    • The back feet recesses are closest to the back edge of the laptop.
    • The front feet recesses are closest to the front edge of the laptop.
    Chiedi a FixBot
  4. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Remove the feet: passo 4, immagine 1 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Remove the feet: passo 4, immagine 2 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Remove the feet: passo 4, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Insert one arm of your tweezers into the recess of one of the feet.
    • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
    • The feet eject very quickly—be careful not to lose them.
    • Remove the foot.
    • Repeat this process on the remaining feet.
    Chiedi a FixBot
  5. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Reassembly information: passo 5, immagine 1 di 2 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Reassembly information: passo 5, immagine 2 di 2
    Tesa 61395 Tape
    $8.95
    • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
    • The rear feet have a single center clip.
    • The front feet have three clips and can only be reinserted one way.
    • Press the feet into their recesses to secure them to the frame.
    • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
    Chiedi a FixBot
  6. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement: passo 6, immagine 1 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement: passo 6, immagine 2 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement: passo 6, immagine 3 di 3
    • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
    • Peel a pad away from its backing.
    • Align the pad over a foot cavity and press down to secure it.
    Chiedi a FixBot
  7. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Unfasten the upper case: passo 7, immagine 1 di 1
    FixMat
    $36.95
    • These screws strip easily. Apply constant, downward force to prevent stripping.
    • Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
    Chiedi a FixBot
  8. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Open the screen: passo 8, immagine 1 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Open the screen: passo 8, immagine 2 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Open the screen: passo 8, immagine 3 di 3
    • Flip your laptop over and fully open the screen.
    Chiedi a FixBot
  9. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Lift the upper case: passo 9, immagine 1 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Lift the upper case: passo 9, immagine 2 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Lift the upper case: passo 9, immagine 3 di 3
    • The upper case is secured by magnets.
    • Grip the top edge of the upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case, as it's still connected to the laptop by a cable.
    • Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the screen could damage the screen as it closes.
    Chiedi a FixBot
  10. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Disconnect the keyboard and touchpad cable: passo 10, immagine 1 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Disconnect the keyboard and touchpad cable: passo 10, immagine 2 di 3 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Disconnect the keyboard and touchpad cable: passo 10, immagine 3 di 3
    • The keyboard and touchpad cable connects the upper case to the laptop.
    • Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
    • To reconnect the cable, align the magnet connector over its socket with the cable facing the bottom of the laptop. Press down on the connector to secure it.
    Chiedi a FixBot
  11. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Remove the upper case: passo 11, immagine 1 di 1
    • Remove the upper case and set it keyboard-side down on a clean surface.
    Chiedi a FixBot
  12. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Unfasten the SSD: passo 12, immagine 1 di 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • With the screw removed, the SSD pops up at a shallow angle.
    Chiedi a FixBot
  13. Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Remove the SSD: passo 13, immagine 1 di 2 Microsoft Surface Laptop 4 (13.5-inch) SSD Replacement, Remove the SSD: passo 13, immagine 2 di 2
    • Removing the SSD also functions as a battery disconnect.
    • Pull the SSD out of its socket and remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
    • During reassembly, insert the SSD at a slight angle.
    Chiedi a FixBot
Conclusione
Altre 6 persone hanno completato questa guida.
Clay Eickemeyer
Membro da: 09/19/22
103.725 Reputazione
476 guide realizzate
Guide Team Membro di Guide Team
Staff
10 Membri
17.798 guide realizzate
1Commento della guida
Does this require a heatsink or thermal paste or anything? I'd assume not as it isn't in the guide, but I am not one to do a lot of installations. I've replaced a PS5 SSD which recommended a heatsink. Maybe the 2230 ssd comes with a heatsink?
T O - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 15
Ultimi 7 giorni: 113
Ultimi 30 giorni: 532
Tutti i Tempi: 18,640
