Salta al contenuto principale
Microsoft Surface RT Kick-stand Replacement
Cosa ti serve
  1. Microsoft Surface RT Kick-stand Replacement, Kick-stand: passo 1, immagine 1 di 2 Microsoft Surface RT Kick-stand Replacement, Kick-stand: passo 1, immagine 2 di 2
    • Turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
    • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
    • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
Conclusione
Altre 13 persone hanno completato questa guida.
Kevin Hua
Membro da: 01/11/13
1.615 Reputazione
3 Guide realizzate
Cal Poly, Team 17-23, Forte Winter 2013 Membro di Cal Poly, Team 17-23, Forte Winter 2013
CPSU-FORTE-W13S17G23
5 Membri
17 Guide realizzate
12 Commenti
Where do you get the replacement kickstand from?
Ray - Replica
is this compatible with surface pro 1 ?
arqueiro - Replica
Do you offer a replacement kickstand for the surface rt 2?
allie - Replica
Does this replacement kickstand come with the screws also?
Andrea Thompson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 30
Tutti i Tempi: 40,584
