Salta al contenuto principale
Microsoft Surface 3 Speaker Replacement
Cosa ti serve
  1. Microsoft Surface 3 Speaker Replacement, Casing: passo 1, immagine 1 di 2 Microsoft Surface 3 Speaker Replacement, Casing: passo 1, immagine 2 di 2
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
  2. Microsoft Surface 3 Speaker Replacement: passo 2, immagine 1 di 2 Microsoft Surface 3 Speaker Replacement: passo 2, immagine 2 di 2
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Microsoft Surface 3 Speaker Replacement: passo 3, immagine 1 di 2 Microsoft Surface 3 Speaker Replacement: passo 3, immagine 2 di 2
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
  4. Microsoft Surface 3 Speaker Replacement: passo 4, immagine 1 di 1
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
  5. Microsoft Surface 3 Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • You will be working in these areas of the Surface 3 in order to replace the speakers.
  6. Microsoft Surface 3 Speaker Replacement: passo 6, immagine 1 di 1
    • Use a pick to get under the speaker part and undo the adhesive that keeps it attached to the back casing.
  7. Microsoft Surface 3 Speaker Replacement: passo 7, immagine 1 di 1
    • Use the pick to gently lift on the red and black wire in order to dislodge the connection between the speaker wire and the motherboard.
  8. Microsoft Surface 3 Speaker Replacement: passo 8, immagine 1 di 2 Microsoft Surface 3 Speaker Replacement: passo 8, immagine 2 di 2
    • Repeat the same steps for the second speaker.
  9. Microsoft Surface 3 Speaker Replacement: passo 9, immagine 1 di 1
    • Simply replace the old speakers by snapping the new speakers into place and connecting the red and black wire to the motherboard.
Conclusione
Andy Stone
Membro da: 10/08/15
284 Reputazione
2 Guide realizzate
Cal Poly, Team 5-12, Maness Fall 2015 Membro di Cal Poly, Team 5-12, Maness Fall 2015
CPSU-MANESS-F15S5G12
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,337
