Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
To replace the battery, you will first need to remove the casing, undo the adhesive under the battery pack, and, finally, remove the battery to replace it.
  1. Warm up an iOpener following the instructions found in the iOpener guide. Place the warm iOpener on top of the edges of the screen.  This heat will weaken the strength of the adhesive between the display and body.
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
  2. Use iFixit opening picks to wedge under the edge of the screen at the speaker port. This may take significant force. A fingernail might work better for the initial lift
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck. If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
    Be very careful on the top edge where the front-facing camera is. The antenna’s for all wireless components are pressed into the adhesive on both the right and left of the camera. I tore off a piece of my wifi antenna here.
    Adam Pyle - Replica
  4. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Flip the display over so that parts underneath it are easily accessible.
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
    Please note that the WIFI antenna can become stuck to the display. It is located on the black plastic to the right of the camera and can be easily disconnected accidentally. Excellent guide otherwise.
    Gary Gleeson - Replica
    I second this comment. Didn’t know it was there. The surface 3 pro guide clearly warns of this in the takeapart.
    Brian Carlson - Replica
  6. Now that you've gotten the casing off of the Surface 3, you can start removing the battery pack.
    • Now that you've gotten the casing off of the Surface 3, you can start removing the battery pack.
  7. Slide the iFixit plastic cards under the compartments of the battery pack. Slide the card around to undo the adhesive under the battery pack Slide the card around to undo the adhesive under the battery pack
    • Slide the iFixit plastic cards under the compartments of the battery pack.
    • Slide the card around to undo the adhesive under the battery pack
  8. Carefully slide the battery's flat power and data connector from its insert. You may now switch out the battery pack for a new one. You may now switch out the battery pack for a new one.
    • Carefully slide the battery's flat power and data connector from its insert.
    • You may now switch out the battery pack for a new one.
    When replacing the battery, the connector will not slide back in where it came from easily. There are small “fingers” that press down on the top of the connector from the bottom of the logic board, they are pressed down against the back of the casing so firmly that the connector will not slide under them, instead the cable will ride up them and jam into the back of the logic board. I’ve found the best solution is to remove the screws from the logic board and use a spudger to gently lift the logic board to make a space under the fingers to allow the connector to slip back in.
    Brad Perkins - Replica
    Be aware of the fragility of the battery connector and ensure that the replacement has got the cut out on the leading edge. I’ve managed to break / snap the connecting cable on the replacement battery :-( so will have to order another and try again (at £25 its worth trying again IMHO).
    If one of this pins holding the ribbon breaks does the mother board still work, with a new battery. Do i need to remove motherboard to instsll battery ribbon. Its hard not to break.
    Ana Rios - Replica
    I took out the six (torx 3) and two (torx 2) screws near the battery terminal. Then used a spudger on the left side of the logic board to get it high enough off the frame to sneak in the battery connector. Worked great. Helps to have an extra hand too.
    Corey S - Replica
    I want to ask that do I need to fold the battery's flat power and data connector first before I slide connector into its insert?
    It does not work when I slide it in, or I just not slide it deep enough?
    tsengkt - Replica
    I installed the battery but it was shorting. Examine a picture of the backside of the motherboard (ebay). There are THREE rows of connector pins to the battery, not just the row you see, and you’ve got to get under all the rows it’s supposed to connect to or it shorts. Only way to do this is to get some screws out and lift the motherboard enough to get it under.
    kevin messerschmidt - Replica
Conclusione
Altre 11 persone hanno completato questa guida.
Johann Cayaban
Membro da: 01/10/2015
513 Reputazione
1 Guida realizzata
Cal Poly, Team 5-12, Maness Fall 2015 Membro di Cal Poly, Team 5-12, Maness Fall 2015
CPSU-MANESS-F15S5G12
4 Membri
12 Guide realizzate
I followed these instructions without a hitch but now that I'm trying to put the new battery in I can't slide the connector for the new battery back in. It seems like the teeth that are supposed to grab the connector for the battery are too tight so I can't side the director for the battery in. Do you have any advise for this issue that I'm having?
John Salazar - Replica
Recently had to complete this repair for a customer. Was in the same boat, couldn’t figure out how to plug the battery back in. And wasn’t paying attention to how the connection was originally, when i pulled the battery. The connector has to slide UNDER the teeth, not above. Meaning loosen the board screws and lift the board slightly, then slide the battery connector in. hopefully this helps others that a stuck with this issue, and iFixit will update this guide.
Marno Junta -
Great pictures and tools shown.
philbu - Replica
Hab’s versucht und es hat leider nicht mal in Ansätzen geklappt. Genau wie beschrieben hab ich den iOpener 30 Sekunden lang in der Mikrowelle erhitzt und dann auf die rechte Seite des Geräts gelegt. Nach ein paar Minuten war ich der Meinung es kann losgehen und hab wie beschrieben an der Einbuchtung des Lautsprechers das Glas leicht angehoben und mit dem Plektrum in flachem Winkel angesetzt. Bevor ich noch groß Kraft anwenden konnte hatte ich schon den Sprung und ein ordentliches Stück Glas ist mir weggesprungen. Zunächst dachte ich dass es halb so schlimm sei, denn es hat “nur” den schwarzen Rand erwischt, nicht jedoch das Tochscreen selbst. Naja nach kurzer Zeit ist der Riss gewandert und nachdem die Tochfunktion nicht mehr ging, kamen danach die bunten Streifen…. 300€ kostet der Displaytausch und noch mal 90€ der Akku tausch. Hätte ich gewusst wie unfassbar leicht das Glas springt, hätte ich sofort den Akkutausch machen lassen und nicht selbst Hand angelegt -.-
Elias Aminger - Replica
Anyone know where to find a photo of the motherboard?
Frank Ho - Replica
Hi Guys. Any idea whether we can replace the SSD in Surface 3. My Surface 3 goes to BSOD loop and i tried resetting and it dint work. Tried memtest86. it passed too. Then used the surface drive eraser tool to wipe the drive clean. but still it goes to bsod while installation reaches some percentage. Tried all possible things with in my resourses. Dint try opening the surface yet. if the ssd is replaceable please let me know whats the ssd model to be bought
Jacob George - Replica
Hi Guys. Any idea whether we can replace the SSD in Surface 3 (1645) . My Surface 3 goes to BSOD loop and i tried resetting and it dint work. Tried memtest86. it passed too. Then used the surface drive eraser tool to wipe the drive clean. but still it goes to bsod while installation reaches some percentage. Tried all possible things with in my resources. Dint try opening the surface yet. if the ssd is replaceable ? please let me know whats the ssd model to be bought. Thanks a lot in advance Stay Safe
Got it all back together with no issues except…. it won’t power up. How long do I need to wait for it to charge the batteries before I can use it. Should I not be able to use it while it’s plugged in and charging?
sam mendolia - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 46
Ultimi 7 Giorni: 322
Ultimi 30 Giorni: 1,236
Tutti i Tempi: 43,933
