Introduzione
To replace the Surface 3 audio jack, you will need to remove the casing, undo various restraints that keep the audio jack in place, and, finally, remove and replace the audio jack itself.
Cosa ti serve
Warm up an iOpener following the instructions found in the iOpener guide.
Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
You will be working in this area of the Surface 3 when replacing the audio jack and Micro SD port
Altre 4 persone hanno completato questa guida.
