Introduzione
You may need to remove the front or back cameras if they have been damaged due to a fall or there seems to be some other problem. When removing the cameras from their respective connections, be sure to pry up on the retaining flap and not the connection itself.
Cosa ti serve
Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
Once all screws have been removed, lift and remove the bezel from the rest of the device.
