Salta al contenuto principale
Microsoft Lumia 640 LTE Motherboard Replacement
Cosa ti serve
  1. Microsoft Lumia 640 LTE Motherboard Replacement, Back Cover: passo 1, immagine 1 di 2 Microsoft Lumia 640 LTE Motherboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Use your thumb or fingernail on the edge/corner of the phone to pry the back cover off the phone.
  2. Microsoft Lumia 640 LTE Motherboard Replacement, Screen: passo 2, immagine 1 di 3 Microsoft Lumia 640 LTE Motherboard Replacement, Screen: passo 2, immagine 2 di 3 Microsoft Lumia 640 LTE Motherboard Replacement, Screen: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers to pull back the sticker, revealing the screw underneath.
    • Be careful when removing the screws as they can strip easily.
  3. Microsoft Lumia 640 LTE Motherboard Replacement: passo 3, immagine 1 di 2 Microsoft Lumia 640 LTE Motherboard Replacement: passo 3, immagine 2 di 2
    • Use a T4 Torx driver to remove the screws in the four corners, along with the two in the middle left side (six total).
  4. Microsoft Lumia 640 LTE Motherboard Replacement: passo 4, immagine 1 di 2 Microsoft Lumia 640 LTE Motherboard Replacement: passo 4, immagine 2 di 2
    • Using the T4 Torx driver, unscrew the two screws.
    • Keep these screws separate from the screws from back of the phone to ensure that the right screws go where they belong.
  5. Microsoft Lumia 640 LTE Motherboard Replacement: passo 5, immagine 1 di 2 Microsoft Lumia 640 LTE Motherboard Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to separate the screen from the back plastic casing
    • Use tweezers to release the clip on the side of device, and remove the back of the phone.
  6. Microsoft Lumia 640 LTE Motherboard Replacement: passo 6, immagine 1 di 2 Microsoft Lumia 640 LTE Motherboard Replacement: passo 6, immagine 2 di 2
    • Using the tweezers or a spudger, pull the gold tab up gently.
    • Using tweezers or a spudger, lift the white connector up gently to completely detach the screen from the phone.
    • For motherboard replacement, skip to Step 11 after finishing this step.
  7. Microsoft Lumia 640 LTE Motherboard Replacement: passo 7, immagine 1 di 3 Microsoft Lumia 640 LTE Motherboard Replacement: passo 7, immagine 2 di 3 Microsoft Lumia 640 LTE Motherboard Replacement: passo 7, immagine 3 di 3
    • Using a plastic opening tool to carefully get under the gold strip.
    • Use tweezers to pull up the camera.
    • Use tweezers to pull up on the depth sensor.
    • This is held in by a strong adhesive.
  8. Microsoft Lumia 640 LTE Motherboard Replacement: passo 8, immagine 1 di 1
    • Use a plastic opening tool to pry up the ear speaker.
    • This is held in by strong adhesive.
  9. Microsoft Lumia 640 LTE Motherboard Replacement, Headphone Jack: passo 9, immagine 1 di 1
    • Unscrew the 2 remaining screws with the T-4 bit.
  10. Microsoft Lumia 640 LTE Motherboard Replacement: passo 10, immagine 1 di 1
    Compra
    • Use the tweezers to remove the speaker.
  11. Microsoft Lumia 640 LTE Motherboard Replacement: passo 11, immagine 1 di 3 Microsoft Lumia 640 LTE Motherboard Replacement: passo 11, immagine 2 di 3 Microsoft Lumia 640 LTE Motherboard Replacement: passo 11, immagine 3 di 3
    • Use the plastic opening tool to lift up the black tab.
    • Use the tweezers to gently pull up on the gold tab.
    • Using the spudger, slowly get underneath the gold sticker and pry it up. This sticker is held down with a strong adhesive.
  12. Microsoft Lumia 640 LTE Motherboard Replacement: passo 12, immagine 1 di 1
    • Use the tweezers to remove the orange insulator foam.
  13. Microsoft Lumia 640 LTE Motherboard Replacement, Motherboard: passo 13, immagine 1 di 1
    • Using the pry tool lift up on the black tab
  14. Microsoft Lumia 640 LTE Motherboard Replacement: passo 14, immagine 1 di 1
    • Using the spudger, press out the motherboard.
  15. Microsoft Lumia 640 LTE Motherboard Replacement: passo 15, immagine 1 di 1
    • Gently wiggle out the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
I have a Microsoft luma 640 LTE ...the battery won't charge ...so I got another battery and it won't power on...the new battery is good...it's the side button that wont power on when I puch it...does the motherboard need to be replaced? I got another Microsoft luma 640 phone that I could switch the motherboard out with my old phone...I'm question is will I be able to access my contacts, pictures etc after changing out the motherboard..
H.wise - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 838
