Salta al contenuto principale
Microsoft Lumia 640 LTE Front Screen Replacement
Cosa ti serve
  1. Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: passo 1, immagine 1 di 3 Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: passo 1, immagine 2 di 3 Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: passo 1, immagine 3 di 3
    • Back comes apart easily
  2. Microsoft Lumia 640 LTE Front Screen Replacement, Peeling of the tape: passo 2, immagine 1 di 2 Microsoft Lumia 640 LTE Front Screen Replacement, Peeling of the tape: passo 2, immagine 2 di 2
    • Peel the tape from left to the right.
    • Under the tape there is a hidden screw.
  3. Microsoft Lumia 640 LTE Front Screen Replacement, Take out the back screws.: passo 3, immagine 1 di 1
    • Take these screws out, and remember organize your screws so you know where they are going when you are putting the phone back together.
  4. Microsoft Lumia 640 LTE Front Screen Replacement, Take out the side screws.: passo 4, immagine 1 di 1
    • Turn the phone on its side and there are two (2) more screws that needs to be taken out.
  5. Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: passo 5, immagine 1 di 3 Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: passo 5, immagine 2 di 3 Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: passo 5, immagine 3 di 3
    • Be careful of the top left corner of the phone, the connecting cable is sitting there.
    • The green arrows indicates where the cable is, so be careful
  6. Microsoft Lumia 640 LTE Front Screen Replacement, Disconnect cables: passo 6, immagine 1 di 2 Microsoft Lumia 640 LTE Front Screen Replacement, Disconnect cables: passo 6, immagine 2 di 2
    • disconnect the two connectors here: Green, and Red.
  7. Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: passo 7, immagine 1 di 3 Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: passo 7, immagine 2 di 3 Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: passo 7, immagine 3 di 3
    • Carefully remove the cable.
    • Top two arrows indicate Camera, and chip. Button arrow indicate the way it is easiest to get the cable off.
  8. Microsoft Lumia 640 LTE Front Screen Replacement, Last step, remove the speaker.: passo 8, immagine 1 di 1
    • The speaker comes out really easy
    • Do not fear, it is not attached by a cable but only glue.
Conclusione
Altre 28 persone hanno completato questa guida.
Nick Johansen
Membro da: 10/09/15
1.991 Reputazione
2 Guide realizzate
18 Commenti
Guys your awesome. I just replaced a cracked screen and it only cost me the price of a new one.
Ron Hudson - Replica
I'm happy to help, please let me know if there was any step that was hard to understand.
Nick Johansen - Replica
Hi guys microsoft lumia 640 front screen cracked where can i have it replaced plz
Delmark Lawrence - Replica
With the ease of replacing these screens and the availability of the part you could attempt it yourself as it is a simple process and a very rewarding one at that!! :) :p
Cory Hibbin -
thanks nick, do you have a picture of the device without speaker and ready to reassembling?
Labartsara Sara - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 26,198
