Salta al contenuto principale
Michael Kors Watch Link Band Replacement
Cosa ti serve
  1. Michael Kors Watch Link Band Replacement, Link Band: passo 1, immagine 1 di 1
    • Place the watch on your wrist and determine whether links should be added or removed.
    • If watchband needs to be expanded, approximate the number of links required.
    I need 1 or 2 linked added to my Michael kors watch
    Jeremy Bendy - Replica
    I need 2 silver band
    pansy parsons - Replica
  2. Michael Kors Watch Link Band Replacement: passo 2, immagine 1 di 3 Michael Kors Watch Link Band Replacement: passo 2, immagine 2 di 3 Michael Kors Watch Link Band Replacement: passo 2, immagine 3 di 3
    • Set the watch on the block holder.
    • Ensure the arrows located on the links are pointing downward.
  3. Michael Kors Watch Link Band Replacement: passo 3, immagine 1 di 1
    • When removing damaged or extra links, hold one end of the pin pusher against the pin to be removed.
    • Strike the other end of the pin pusher with the metal side of the watch hammer until the pin slides out.
    • Two pins hold each link to the band, so two pins must be removed per link.
    look on the inside of the band, a lot of manufacturers put a directional arrow to show you which way to remove/insert the band pin, this is because these pins have a larger end on one side, if no arrow is present then removal is bi-directional…having said this, make sure your band doesn’t use screw pins, high grades like Rolex and others use screws….
    C. Hunt - Replica
  4. Michael Kors Watch Link Band Replacement: passo 4, immagine 1 di 1
    • Discard the broken links or save any extra links that you remove.
  5. Michael Kors Watch Link Band Replacement: passo 5, immagine 1 di 2 Michael Kors Watch Link Band Replacement: passo 5, immagine 2 di 2
    • To add links to the watchband, position the watch on the block holder with the arrows facing upward.
    • Insert pins into the holes that connect the new link to the rest of the watchband.
    • Use the soft side of the hammer to strike the pin down.
  6. Michael Kors Watch Link Band Replacement: passo 6, immagine 1 di 2 Michael Kors Watch Link Band Replacement: passo 6, immagine 2 di 2
    • Lastly, make sure that all the pins joining the links are secured in place.
Conclusione
Altre 6 persone hanno completato questa guida.
9 Commenti
How do I replace a broken link when it's the very first link that connects the band to the actual watch?
Karen Perri - Replica
How can I puchace the first link on my Michael kors ceramic watch
melissa.costello31 -
I need first link to attach to micheal kors ceramic white watch
The lady when I bought my watch at the mall told me that Michael Kors will give you two free links I'm trying to figure out how I can go about getting that
Claudia Mead - Replica
Where can I get the white bands that cover the links on my my watch as a few have bits broken
Karenclemo@gmail.com - Replica
Where can I get the white rubber link covers for strap on my mk watch
I need extra links for the MK-5249, where can I get them?
Lucky Stewart - Replica
How do you get extra links for my husband watch
Patty Warren - Replica
I need 2 links for Michael Kors watch number 5864. How do I go about getting the links?
Diana Olson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 433
Tutti i Tempi: 73,042
