Salta al contenuto principale
MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement
Cosa ti serve
  1. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Determine the unloader assembly: passo 1, immagine 1 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Determine the unloader assembly: passo 1, immagine 2 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Determine the unloader assembly: passo 1, immagine 3 di 3
    • There are two versions of the unloader assembly:
    • First image—earlier pressure washers feature an all-in-one assembly (part 8-0631) that’s easy to replace, but gave users the ability to break the pump.
    • Second image—later models use a tamper-proof, harder to remove unloader (part 8-0656), connected by a series of pipe fittings.
    • This guide is written for the tamper-proof unloader assembly.
    • If you need to remove an all-in-one style unloader, use a large adjustable wrench to unscrew the two large Banjo bolts. This will disconnect the unloader from the pump assembly.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement: passo 2, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement: passo 2, immagine 2 di 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the hose clamp: passo 3, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the hose clamp: passo 3, immagine 2 di 2
    • Use a 1/4" socket or a large flathead screwdriver to loosen the hose clamp near the inlet filter.
    • Slide the hose clamp away from the end of the hose.
  4. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Disconnect the return hose: passo 4, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Disconnect the return hose: passo 4, immagine 2 di 2
    • Wiggle the hose and pull it off of the brass nipple.
  5. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Position the support block: passo 5, immagine 1 di 1
    • Slide a 3" tall block underneath the pump assembly to help support the pump.
  6. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Re-position the return elbow: passo 6, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Re-position the return elbow: passo 6, immagine 2 di 2
    • Use a 1/2" or adjustable wrench to loosen and twist the return elbow half a turn, so that it faces the opposite direction.
    • This will allow the fitting to clear the pump edge without being removed.
  7. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the filter: passo 7, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the filter: passo 7, immagine 2 di 2
    • Use a large adjustable wrench to loosen and unscrew the filter.
  8. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the filter: passo 8, immagine 1 di 1
    • Remove the filter with the return elbow attached.
  9. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the input elbow: passo 9, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the input elbow: passo 9, immagine 2 di 2
    • Use a 1" or large adjustable wrench to loosen and unscrew the pump input elbow.
  10. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the input elbow: passo 10, immagine 1 di 1
    • Remove the input elbow fitting.
  11. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the output assembly: passo 11, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the output assembly: passo 11, immagine 2 di 2
    • Use a 3/4" or adjustable wrench to loosen and disconnect the coupling from the pump assembly.
  12. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the output assembly: passo 12, immagine 1 di 1
    • Remove the output assembly.
  13. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Align the axle: passo 13, immagine 1 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Align the axle: passo 13, immagine 2 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Align the axle: passo 13, immagine 3 di 3
    • Look through the top access hole on the pump, near the engine coupling. You should be able to see the pump shaft through the hole.
    • Slowly pull the starter cable. This will slowly turn the engine's axle.
    • Keep rotating the axle until you can see the set screw through the access hole.
  14. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the set screw: passo 14, immagine 1 di 1
    • Insert a 2.5 mm hex key into the set screw and loosen it counter-clockwise by two full turns.
    • Do not completely loosen the screw, or you will lose it.
  15. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the mounting bolts: passo 15, immagine 1 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the mounting bolts: passo 15, immagine 2 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the mounting bolts: passo 15, immagine 3 di 3
    • Use a 1/2" wrench to remove the four 30 mm long bolts which mount the pump to the engine.
    • You should still have the support block under the pump assembly to help bear the pump's weight.
    • Re-assembly tip: note how the washers are stacked when reinstalling the bolts.
    • Replace the lock washers with new ones.
  16. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Slide the pump assembly off: passo 16, immagine 1 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Slide the pump assembly off: passo 16, immagine 2 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Slide the pump assembly off: passo 16, immagine 3 di 3
    • Carefully pull the pump assembly away from the engine until it de-couples from the engine axle.
    • If you are having a hard time pulling the pump away, loosen the axle set screw by half a turn, and try again.
  17. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the axle key: passo 17, immagine 1 di 1
    • Remove the axle key from either the engine axle, or the pump shaft.
    • Re-assembly note: Wipe the axle and key clean and coat with lubricating oil.
  18. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Re-attach the motor: passo 18, immagine 1 di 1
    • Re-assembly note: To re-attach the motor:
    • Press the axle key into the notch on the engine axle.
    • Align the pump shaft with the keyed axle. You may have to rotate the pump to do so.
    • Slide the pump onto the axle until the coupling surfaces touch.
    • If there is a significant gap between the pump and engine, pull the pump off, and re-set the axle key.
Conclusione
When you re-connect the fittings, clean off the old thread sealant and apply new thread sealant (tape or pipe dope).
Arthur Shi
Membro da: 01/03/18
282.844 Reputazione
587 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.474 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,569
