Salta al contenuto principale
Meta Quest 3 Controller Strap Replacement
Cosa ti serve
  1. Meta Quest 3 Controller Strap Replacement, Controller straps: passo 1, immagine 1 di 1
    • First, you will want to pick up any of the controllers to begin replacing the wrist strap.
    Chiedi a FixBot
    Aggiungi Commento
  2. Meta Quest 3 Controller Strap Replacement: passo 2, immagine 1 di 1
    • Adjacent to the controller's joystick is a white triangle button.
    • You need to press down firmly on the button to open the controller's battery compartment.
    Chiedi a FixBot
    Aggiungi Commento
  3. Meta Quest 3 Controller Strap Replacement: passo 3, immagine 1 di 2 Meta Quest 3 Controller Strap Replacement: passo 3, immagine 2 di 2
    • Once you open the compartment, pinch and pull up the strap to disconnect it from the controller.
    Chiedi a FixBot
    Aggiungi Commento
  4. Meta Quest 3 Controller Strap Replacement: passo 4, immagine 1 di 1
    • Grab the corresponding wrist strap for the controller you are working on.
    Chiedi a FixBot
    Aggiungi Commento
  5. Meta Quest 3 Controller Strap Replacement: passo 5, immagine 1 di 2 Meta Quest 3 Controller Strap Replacement: passo 5, immagine 2 di 2
    • With the new wrist strap, push the black clip down into the now-empty small compartment to connect your new strap to the controller.
    Chiedi a FixBot
    Aggiungi Commento
  6. Meta Quest 3 Controller Strap Replacement: passo 6, immagine 1 di 2 Meta Quest 3 Controller Strap Replacement: passo 6, immagine 2 di 2
    • You can close the battery compartment using the new cover connected to the controller strap.
    • Closing the battery compartment can be frustrating because it is connected to the strap; I found it easier to slide the cover from the bottom to the top.
    • The new controller straps come with new battery compartment covers, so when you replace the straps, you will end up with spare parts.
    Chiedi a FixBot
    Aggiungi Commento
  7. Meta Quest 3 Controller Strap Replacement: passo 7, immagine 1 di 3 Meta Quest 3 Controller Strap Replacement: passo 7, immagine 2 di 3 Meta Quest 3 Controller Strap Replacement: passo 7, immagine 3 di 3
    • Put the controller in your hands to see if you need to adjust the fit of the strap.
    • If Adjustments are needed, you can pull or push the strap through the clip's hole.
    Chiedi a FixBot
    Aggiungi Commento
  8. Meta Quest 3 Controller Strap Replacement: passo 8, immagine 1 di 2 Meta Quest 3 Controller Strap Replacement: passo 8, immagine 2 di 2
    • Next, repeat steps 2-7 on the second controller.
    • As mentioned in step 6, you will have spare parts left over from the original wrist strap and battery cover. Store these parts somewhere safe if you ever feel like reverting to the original controller straps.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Once you have followed all these steps, you will have properly applied the accessory to your oculus quest 3 controllers.
Altre 2 persone hanno completato questa guida.
Andrew28709
Membro da: 10/18/23
184 Reputazione
Una guida realizzata
CSU Los Angeles, Team 3-17, Briggs Fall 2023 Membro di CSU Los Angeles, Team 3-17, Briggs Fall 2023
CSULA-BRIGGS-F23S3G17
Membro di 1
1 guide realizzate
1Commento della guida
how do o fix my controller
Zzopekvr VR - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 75
Ultimi 30 giorni: 313
Tutti i Tempi: 8,368
