Salta al contenuto principale
MerchSource the Black Series Boat Racer Gaskets Replacement
Cosa ti serve
  1. MerchSource the Black Series Boat Racer Gaskets Replacement, Gaskets: passo 1, immagine 1 di 2 MerchSource the Black Series Boat Racer Gaskets Replacement, Gaskets: passo 1, immagine 2 di 2
    • Remove the screw on the top of the boat at the rear end using a Phillips #2 screwdriver.
    • Screw length is 16 mm.
  2. MerchSource the Black Series Boat Racer Gaskets Replacement: passo 2, immagine 1 di 3 MerchSource the Black Series Boat Racer Gaskets Replacement: passo 2, immagine 2 di 3 MerchSource the Black Series Boat Racer Gaskets Replacement: passo 2, immagine 3 di 3
    • Remove the top of the boat by sliding it backwards and then pulling it off.
  3. MerchSource the Black Series Boat Racer Gaskets Replacement: passo 3, immagine 1 di 2 MerchSource the Black Series Boat Racer Gaskets Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Grab the rubber gasket with tweezers and pull it out of the slot.
  4. MerchSource the Black Series Boat Racer Gaskets Replacement: passo 4, immagine 1 di 3 MerchSource the Black Series Boat Racer Gaskets Replacement: passo 4, immagine 2 di 3 MerchSource the Black Series Boat Racer Gaskets Replacement: passo 4, immagine 3 di 3
    • Gently remove the gasket and replace with a new one.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 271
